Import einer lib
Hi,
lässt sich das anhängende Modell in LTSpice einfügen und arbeiten? Wenn ja, wie?
Es handelt sich um einen VJFET N-channel
Gruss
Calvin
* model based on measured data (temperature range 25°C-250°C)
* of a typical 1200V JFET mounted in TO220
* content:
* JFET_INF04_1200V_L1
* JFET_INF04_1200V_L3
* JFET_INF04_1200V_L3b
* Example:
*XJFET Drain Gate Source JFET_INF04_1200V_L1
* XJFET Drain Gate Source Tj TCase JFET_INF04_1200V_L3 LossSwitch=1
* XJFET Drain Gate Source Tj TAmb TCase JFET_INF04_1200V_L3b LossSwitch=1
* LossSwitch = 0 -> dissipated power = 0 (default value, can be omitted)
* LossSwitch <> 0 -> dissipated power = Current_JFET x Voltage_JFET
* thermal nodes of level 3 model:
* JFET_INF04_1200V_L3 :
* Tj : potential(in V) = temperature (in °C) at junction (monitor node, typically not connected)
* Tcase : node where the boundary contition - external heat
* sinks etc - have to be connected (ideal heat sink
* can be modeled by using a voltage source stating the
* ambient temperature in °C between Tcase and ground.
* JFET_INF04_1200V_L3b :
* Equivalent to L3, usage of thermal nodes TCase and Tamb as in the previos model JFET_Mod_D41_V1.1C
.SUBCKT JFET_1200 D G S Tj PARAMS: a=1 LossSwitch=0
.PARAM ISP1A = 9.5038E-2 ISP1B = -2.1720E-4 ISP2A = -2.0088E-3 ISP2B = 6.5673E-6
.PARAM ISP3A = -1.9000E1 ISP3B = 0 KRP1A = 5.1770E-2 KRP1B = 9.4692E-5
.PARAM KRP2A = -1.6794E-3 KRP2B = -2.4340E-7 KRP3A = -1.9000E1 KRP3B = 0
.PARAM f2=130p f1a=17.49p f1b=2767.6p f1c=769.5p f1d=44.27p f3=180p Cmax=900p
.PARAM U0=2.9 ps2={-1/2.5} ps3={-1/12.32} ps4={-1/193.3}
.PARAM ps9={(ln(Cmax/f1b))/ps2}
.PARAM Cds0={f2*a}
.PARAM Cox1={f1a}
.PARAM Cox2={Cmax}
.PARAM Cox3={f1c}
.PARAM Cox4={f1d}
.PARAM Cgs={f3*a}
.FUNC KRP1(T) { KRP1A + KRP1B*T }
.FUNC KRP2(T) { KRP2A + KRP2B*T }
.FUNC KRP3(T) { KRP3A + KRP3B*T }
.FUNC ISP1(T) { ISP1A + ISP1B*T }
.FUNC ISP2(T) { ISP2A + ISP2B*T }
.FUNC ISP3(T) { ISP3A + ISP3B*T }
.FUNC KR(T,VG) { (KRP1(T)*(VG-KRP3(T))*(VG-KRP3(T)))+(KRP2(T)*(VG-KRP3(T))*(VG-KRP3(T))*(VG-KRP3(T))) }
.FUNC IS(T,VG) { (ISP1(T)*(VG-ISP3(T))*(VG-ISP3(T)))+(ISP2(T)*(VG-ISP3(T))*(VG-ISP3(T))*(VG-ISP3(T))) }
.FUNC ID(T,VG,VD) {IF( VG>ISP3A,(VD/abs(VD))*IS(T,VG)*(1-exp(-abs(VD)/KR(T,VG))),1e-9 ) }
*JFET current
GIDK d s0 VALUE = {ID(V(Tj,0),V(g,s),V(d,s))}
Vcurr s0 s DC=0
*gate diodes
DA g g1 DGF
DB s g1 DGS
RGS g s 5.65E8
.model DGF D (LEVEL=1 BV=28 RS=0.05)
.model DGS D (LEVEL=1 BV=1.44 RS=70)
E_Eds d edep VALUE {(V(d,s)-2*(SQRT(U0*(limit(U0+V(d,s),0,2000)))-U0))}
C_Cds edep s {Cds0}
Vx d ox1 0
C_Cdg1 ox1 g {Cox1}
E_Edg2 d ox2 VALUE
+ {if(V(d,g)>ps9,V(d,g)-(1/ps2*(exp(ps2*V(d,g))-exp(ps2*min(V(d,g),ps9)))+min(V(d,g),ps9)),0)}
C_Cdg2 ox2 g {Cox2}
E_Edg3 d ox3 VALUE {if(V(d,g)>0,V(d,g)-(exp(ps3*max(V(d,g),0))-1)/ps3,0)}
C_Cdg3 ox3 g {Cox3}
E_Edg4 d ox4 VALUE {if(V(d,g)>0,V(d,g)-(exp(ps4*max(V(d,g),0))-1)/ps4,0)}
C_Cdg4 ox4 g {Cox4}
Cgs g s {Cgs}
*reverse diode (vers. v1.1d)
D1 s0 mid FWDBL1
D2 s0 mid FWDBL2
.MODEL FWDBL1 D RS=0.0 BV=10000
.MODEL FWDBL2 D RS=60k BV=1120
.PARAM RWDA = 1.086
.PARAM RWDB = 0.453
EDIO1 mid miv1 VALUE = {IF(V(s0,mi) > RWDA, RWDA+sqrt(I(VID0)/RWDB)-0.90, 0)}
EDIO2 miv1 miv2 VALUE = {IF(V(s0,mi) <= RWDA, IF(V(s0,mi) > 0, I(VID0)*1e9, 0), 0)}
VID0 miv2 mi 0
VITOT mi d 0
*thermal
G_TH 0 Tj VALUE={ LIMIT(IF(LossSwitch==0,0,abs(I(Vcurr)*(V(d,s))) ),0,1e6)}
.ENDS
.SUBCKT JFET_INF04_1200V_L1 drain gate source PARAMS: Ls=1n Ld=1n Lg=5n
.PARAM act=3.39 Rg=14 dgfs=0
X1 d g s Tj JFET_1200 PARAMS: a={act}
Rg g1 g {Rg}
Lg gate g1 {Lg*if(dgfs==99,0,1)}
Ls source s {Ls*if(dgfs==99,0,1)}
Ld drain d {Ld*if(dgfs==99,0,1)}
E1 Tj w VALUE={TEMP}
R1 w 0 1u
.ENDS
.SUBCKT JFET_INF04_1200V_L3 drain gate source Tj Tcase PARAMS: Ls=1n Ld=1n Lg=5n LossSwitch=0
X1 d g s Tj JFET_1200 PARAMS: a={act} LossSwitch={LossSwitch}
Rg g1 g {Rg}
RTH1 Tj TH1 0.217
RTH2 TH1 TH2 0.430
RTH3 TH2 TH3 0.267
RTH4 TH3 TCase 0.154
CTH1 Tj 0 0.00052
CTH2 TH1 0 0.0042
CTH3 TH2 0 0.029
CTH4 TH3 0 0.239
CTH5 TCase 0 0.239
.ENDS
.SUBCKT JFET_INF04_1200V_L3b drain gate source Tj Tamb Tcase PARAMS: Ls=1n Ld=1n Lg=5n LossSwitch=0
Rg g1 g {Rg}
RTH1 Tj TH1 0.217
RTH2 TH1 TH2 0.430
RTH3 TH2 TH3 0.267
CTH1 Tj Tamb 0.00052
CTH2 TH1 Tamb 0.0042
CTH3 TH2 Tamb 0.029
CTH4 TH3 Tamb 0.239
.ENDS
Hey... cool, JFet's, die heiß werden und an die man einen virtuellen Kühlkörper anschließen kann überrascht Heart . Klar geht das. Wenn:
- das ein PSpice-Modell ohne Fehler ist (wo kommt das eigentlich her und gibt es da noch mehr?),
- jemand ein passendes Symbol mit einem Messpunkt zur Temperaturmessung und einem Kühlkörperanschluss erstellt.
ein jfet mit 1200v wow überrascht
Calvin hat etwas "vergessen" Tongue
Zitat:* Copyright: SiCED GmbH&Co.KG * **************************************************************** * Models provided by SiCED are not warranted by SiCED as * fully representing all of the specifications and operating * characteristics of the semiconductor product to which the * model relates. The model describe the characteristics of a * typical device. * In all cases, the current data sheet information for a given * device is the final design guideline and the only actual * performance garantee. * Altough models can be a useful tool in evaluating device * performance, they cannot model exact device performance under * all conditions, nor are they intended to replace bread- * boarding for final verification. SiCED reserves the right * to change models without prior notice.
von hier:
http://www.siced.de/hp733/Schaltbauelemente.htm
ich hab's mal versucht. normalerweise soll der temp pin nur zum messen sein aber ltspice mag's irgendwie nicht wenn man ihn unbeschaltet lässt.
tempfet <--- so gehts nicht sind ja 3 modelle in der datei
so sieht's besser aus tempfet die 2.
und hier ein test in swcad
https://stromrichter.org/d-amp/content/i...00test.asc
puhh, echt gut dass es ne simu is Rolleyes
hatte vorher kleinen fehler...ca 10exp38 A gate-strom überrascht
den blitz hätte kahlo wohl noch gesehen...
[Bild: nuclear_bomb.jpg]
aber warm wird er nicht Rolleyes
Hi,
wunderbar, danke sehr für die schnelle Klärung.
Es scheint das mit der SiC-Technologie eine mittelprächtige Revolution ins Haus steht. Hochvolt-Hochtemperatur-Hochgeschwindigkeits-Transistoren die in Versuchen bis 11kV, oder 500°C oder 43GHz liefen und wie´s aussieht kurz vor der Markrreife sind. Laut einer japanischen Studie könnte alleine durch die konsequente Anwendung der SiC-SIT-Technologie der CO²-Ausstoss 2020 auf 1% des Niveaus von 1990 gesenkt werden.
Die Schnelligkeit, verbunden mit sehr niedrigen On-Widerständen ist für alle geschalteten Anwendungen interessant.
Mich interessiert eher die Anwendung als HV-amp für Elektrostaten um entweder von den gestackten Transen-Topologien oder den aufgeheizten Röhren weg zu kommen. Ein komplett mit JFETs aufgebauter HV-Amp, schön in SE class-A und möglichst ohne global feedback müsste klanglich mit einer Röhre nicht nur sehr gut mithalten können, sondern insgesamt vorteilhaft sein Confused
jauu
Calvin
